Zbieramy chętnych na KLZE
Arturo77
Post autor: Arturo77 »
prosze bardzo. w wolnym tlumaczeniu :)
1. Most KLZE engines were automatics. Did this present a problem when installing in an MTX PGT?
Mine came from an automatic and there wasnt any problems at all during installation.
- Wiekszosc silnikow KLZE jezdzilo z automatem, czy zainstalowanie go z manualem stwarza problemy?
- nie
2. I understand that the only swap you MUST do is the Disty....however some people have swapped out the TB and VAF. What did you do?
I am using the disty and vaf from my KL-03 motor, the TB is the ZE
chodzi o rozdzielacz zaplonu zapewne (disty), VAF to przeplywomierz
gosc uzywa tego ze KLO3, natomiast TB jest z KLZE
3. I know the EGR needs to be tapped on the intake manifold...but...how many of you just said F-it and didn't install the EGR?
I just said F-it
- EGR musi byc zalozony na dolot, ilu z was stwierdzilo ze... nie bedzie sobie zawracac glowy ;) i nie instalowalo EGRu?
- ja nie zawracalem sobie glowy ;)
4. If you said F-it to the above did the reprogrammed CPU eliminate the check engine light that you get with the OEM ECU? (You do get a check engine light right?)
I'm still using the KL-03 ecu and I get the check engine light still
- czy przeprogramowanie CPU wyeliminowalo problem swiecacej sie kontrolki (z powodu braku EGRu) check engine?
- ja mam stare CPU i kontrolka check engine sie swieci.
5. If you did install the EGR how did you do it? Any "really neat way" to make it all work?
F-it!
jezeli zainstalowaliscie EGR, jak to zrobiliscie? jest jakis ladny sposob by to wszystko dzialalo?
daj sobie spokoj :)
6. Just for laughs..what kind of mileage are you getting with the ZE?
about the same as the 03
- tak dla jaj: jakie przebiegi osiagacie na KLZE?
- takie same jak na KL03
7. How many of you have the eratic idle problem?
not me
- ilu z was ma problem z biegiem jalowym?
- nie ja
8. How many of you re-installed the AC and cruise?
I did and they both work fine
- ilu z was reinstalowalo klime i kontrole trakcji?
- ja i oba dzialaja
9. Does the ZE have HLA noise and if so can it be corrected prior to install.
No noises here
- czy w KLZE halasuja popychacze i czy moze to byc skorygowane przed instalacja silnika
- nie ma zadnych halasow
10. If installed pheno's any clearance problems with the hood?
I have the phenolic spacers installed and I dont have any hood clearance problems
phenolic spacers - o ile rozumiem zastepuje uszczelke miedzy kolektorem ssacym a glowica, jest z hydroksybenzenu i ma za zadanie "chlodzic" dolot (prawdopodobnie przez to ze stanowi izoluje termicznie kolektor), podobno dodaje pare koni, ale moze powodowac ze "podwyzszony" kolektor ssacy nie miesci sie pod maska.
odpowiedz jest taka ze sie miesci. nie podaja jakiej grubosci sa te "dystanse", ja znalazlem cos o cwierccalowych.
11. Does it come with exhaust manifolds all the way back to the cat or just the downpipe?
Mine didnt come with any exhaust manifolds. I am using the stock manifolds from my old motor
- czy (KLZE) przychodzi z kolektorem wydechowym az do katalizatora czy tylko do rury wdechowej?
- moj byl bez zadnego kolektora wydechowego. uzywam tego ze starego silnika.
12. Does it use the same O2 sensors?
yup
- czy pasuja stare sondy lambda?
- tak
A może ktoś to może dokładnie przetłumaczyć, bo ja paru stwierdzeń nie rozumiem.
somebody can translate it, I don`t get it??
ups, eeee. juz koniec?? :)))
a w ogole ja sie pisze na KLZE lub na turbine, ALE jak juz technologia bedzie opanowana i zobacze jezdzace auto :)
nosferattu
Post autor: nosferattu »
Hay/<,, wiem jak wtisnac KLZE, moge podpowiedziec, u nas juz jezdi 23 auto z nowym silnikiem, problem w tym ze zle muwie po polsku, ale postaram sie odpowiedziec na wszystkie pytania///
Probe II KL
Lukask
Samochód: Bardzo szybki :P
Galeria: viewtopic.php?t=6860
Post autor: Lukask »
A macie jakąś swoją stronkę i fotki tych bestii ??
moto
Post autor: moto »
nosferattu a moze macie jakies wykresy z chamowni
osiągi??
nosferattu
Ciesc!!!
Co do strony internetowoj, to ociewiscie mamy, na dzien dzisiejszy istnieje dwa kluby.
www.forum.probe.ru
www.probe.org.ru
Co do kosztow, to dzis napisze, jak to u nas wyglada, gde i jak to sie zamawia, ile czasu bedzie jehac silnik i co gdzie sie wkreca + naiwazniejsze: po co to sie robi....
Probe II KL
wingerman
Samochód: Probe 3.0L
Post autor: wingerman »
ech... wszystko cyrulica :( 8-|
nosferattu
wingerman pisze:ech... wszystko cyrulica :( 8-|
A ty myslales, ze my tam po polsku piszemy? :D
Probe II KL
Lukask
Też próbowałem coś odczytać ale za cianki jestem :)
A ty nieźle władasz polskim 8)
wingerman
mialem nadzieje ze po angielsku.
Zdaje sie ze bedziesz proszony (niejednokrotnie) o translacje (tlumaczenie) mamy nadzieje, ze podolasz :)
nosferattu
wingerman pisze:mialem nadzieje ze po angielsku.
Bede sie staral...
Probe II KL
nosferattu pisze:zle muwie po polsku
lukask pisze:A ty nieźle władasz polskim 8)
Говориш лучше (несомненно не xужe) чем часть членов нaшего форума :twisted:
(Господи, как можно это склонять :shock: - по-польски всегда "форум")
nosferattu pisze:na dzien dzisiejszy istnieje dwa kluby.
У нас тоже 8)
ZENiTH
Galeria: viewtopic.php?t=6493
Post autor: ZENiTH »
Robert przetłumacz to po polsku bo ja i pewnie cała reszta nic z tego nie kapuje.
Titanium Fox
nosferattu
Robert pisze:
У нас тоже 8)
Sorry nie wiedzalem, ale jednak dzienki ze powiedziales.
Probe II KL
zenith839 pisze:Robert przetłumacz to po polsku bo ja i pewnie cała reszta nic z tego nie kapuje.
Że mówi lepiej, niż część naszych forumowiczów :twisted: i że też mamy 2 kluby...
Gturbo
Post autor: Gturbo »
Niedlugo ja bede sprzedawal swoj KLZE. Jest to sprawdzony w 100% silnik. Mam jeszcze na dodatek ECU i MAF do tego. Ceny jeszcze nie wiem.
Wróć do „Mechaniczny”
