Nie wiem jak dokładnie się odbywa zczytywanie kodów, ale na pewno poprzez specjalen urządzenie, czy da się jeszcze jakoś inaczej to nie wiem.
OBD II TROUBLE CODES
P0000 No Failures
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Malfunction
P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem
P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch "A" Circuit Intermittent
P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature For Stable Operation
P0130 O2Circuit Malfunction (Bank #1 Sensor #1)
P0131 O2Sensor Circuit Low Voltage (Bank #1 Sensor #1)
P0132 O2Sensor Circuit High Voltage (Bank #1 Sensor #1)
P0133 O2Sensor Circuit Slow Response (Bank #1 Sensor #1)
P0134 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #1)
P0135 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #1)
P0136 O2Sensor Circuit Malfunction (Bank #1 Sensor #2)
P0137 O2Sensor Circuit Low Voltage (Bank #1 Sensor #2)
P0138 O2Sensor Circuit High Voltage (Bank #1 Sensor #2)
P0139 O2Sensor Circuit Slow Response (Bank #1 Sensor #2)
P0140 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #2)
P0141 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #2)
P0142 O2Sensor Circuit Malfunction (Bank #1 Sensor #3)
P0143 O2Sensor Circuit Low Voltage (Bank #1 Sensor #3)
P0144 O2Sensor Circuit High Voltage (Bank #1 Sensor #3)
P0145 O2Sensor Circuit Slow Response (Bank #1 Sensor #3)
P0146 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #3)
P0147 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #3)
P0150 O2Sensor Circuit Malfunction (Bank #2 Sensor #1)
P0151 O2Sensor Circuit Low Voltage (Bank #2 Sensor #1)
P0152 O2Sensor Circuit High Voltage (Bank #2 Sensor #1)
P0153 O2Sensor Circuit Slow Response (Bank #2 Sensor #1)
P0154 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #1)
P0155 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #1)
P0156 O2Sensor Circuit Malfunction (Bank #2 Sensor #2)
P0157 O2Sensor Circuit Low Voltage (Bank #2 Sensor #2)
P0158 O2Sensor Circuit High Voltage (Bank #2 Sensor #2)
P0159 O2Sensor Circuit Slow Response (Bank #2 Sensor #2)
P0160 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #2)
P0161 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #2)
P0162 O2Sensor Circuit Malfunction (Bank #2 Sensor #3)
P0163 O2Sensor Circuit Low Voltage (Bank #2 Sensor #3)
P0164 O2Sensor Circuit High Voltage (Bank #2 Sensor #3)
P0165 O2Sensor Circuit Slow Response (Bank #2 Sensor #3)
P0166 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #3)
P0167 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #3)
P0170 Fuel Trim Malfunction (Bank #1)
P0171 System Too Lean (Bank #1)
P0172 System Too Rich (Bank #1)
P0173 Fuel Trim Malfunction (Bank #2)
P0174 System Too Lean (Bank #2)
P0175 System Too Rich (Bank #2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor "A" Circuit Malfunction
P0181 Fuel Temperature Sensor "A" Circuit Range/Performance
P0182 Fuel Temperature Sensor "A" Circuit Low Input
P0183 Fuel Temperature Sensor "A" Circuit High Input
P0184 Fuel Temperature Sensor "A" Circuit Intermittent
P0185 Fuel Temperature Sensor "B" Circuit Malfunction
P0186 Fuel Temperature Sensor "B" Circuit Range/Performance
P0187 Fuel Temperature Sensor "B" Circuit Low Input
P0188 Fuel Temperature Sensor "B" Circuit High Input
P0189 Fuel Temperature Sensor "B" Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction--Cylinder #1
P0202 Injector Circuit Malfunction--Cylinder #2
P0203 Injector Circuit Malfunction--Cylinder #3
P0204 Injector Circuit Malfunction--Cylinder #4
P0205 Injector Circuit Malfunction--Cylinder #5
P0206 Injector Circuit Malfunction--Cylinder #6
P0207 Injector Circuit Malfunction--Cylinder #7
P0208 Injector Circuit Malfunction--Cylinder #8
P0209 Injector Circuit Malfunction--Cylinder #9
P0210 Injector Circuit Malfunction--Cylinder #10
P0213 Cold Start Injector #1 Malfunction
P0214 Cold Start Injector #2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Over Temperature Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Over Speed Condition
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Malfunction
P0221 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance Problem
P0222 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input
P0224 Throttle/Pedal Position Sensor/Switch "B" Circuit Intermittent
P0225 Throttle/Pedal Position Sensor/Switch "C" Circuit Malfunction
P0226 Throttle/Pedal Position Sensor/Switch "C" Circuit Range/Performance Problem
P0227 Throttle/Pedal Position Sensor/Switch "C" Circuit Low Input
P0228 Throttle/Pedal Position Sensor/Switch "C" Circuit High Input
P0229 Throttle/Pedal Position Sensor/Switch "C" Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Over Boost Condition
P0261 Cylinder #1 Injector Circuit Low
P0262 Cylinder #1 Injector Circuit High
P0263 Cylinder #1 Contribution/Balance Fault
P0264 Cylinder #2 Injector Circuit Low
P0265 Cylinder #2 Injector Circuit High
P0266 Cylinder #2 Contribution/Balance Fault
P0267 Cylinder #3 Injector Circuit Low
P0268 Cylinder #3 Injector Circuit High
P0269 Cylinder #3 Contribution/Balance Fault
P0270 Cylinder #4 Injector Circuit Low
P0271 Cylinder #4 Injector Circuit High
P0272 Cylinder #4 Contribution/Balance Fault
P0273 Cylinder #5 Injector Circuit Low
P0274 Cylinder #5 Injector Circuit High
P0275 Cylinder #5 Contribution/Balance Fault
P0276 Cylinder #6 Injector Circuit Low
P0277 Cylinder #6 Injector Circuit High
P0278 Cylinder #6 Contribution/Balance Fault
P0279 Cylinder #7 Injector Circuit Low
P0280 Cylinder #7 Injector Circuit High
P0281 Cylinder #7 Contribution/Balance Fault
P0282 Cylinder #8 Injector Circuit Low
P0283 Cylinder #8 Injector Circuit High
P0284 Cylinder #8 Contribution/Balance Fault
P0285 Cylinder #9 Injector Circuit Low
P0286 Cylinder #9 Injector Circuit High
P0287 Cylinder #9 Contribution/Balance Fault
P0288 Cylinder #10 Injector Circuit Low
P0289 Cylinder #10 Injector Circuit High
P0290 Cylinder #10 Contribution/Balance Fault
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder #1--Misfire Detected
P0302 Cylinder #2--Misfire Detected
P0303 Cylinder #3--Misfire Detected
P0304 Cylinder #4--Misfire Detected
P0305 Cylinder #5--Misfire Detected
P0306 Cylinder #6--Misfire Detected
P0307 Cylinder #7--Misfire Detected
P0308 Cylinder #8--Misfire Detected
P0309 Cylinder #9--Misfire Detected
P0310 Cylinder #10--Misfire Detected
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor #1--Circuit Malfunction (Bank #1 or Single Sensor)
P0326 Knock Sensor #1--Circuit Range/Performance (Bank #1 or Single Sensor)
P0327 Knock Sensor #1--Circuit Low Input (Bank #1 or Single Sensor)
P0328 Knock Sensor #1--Circuit High Input (Bank #1 or Single Sensor)
P0329 Knock Sensor #1--Circuit Input Intermittent (Bank #1 or Single Sensor)
P0330 Knock Sensor #2--Circuit Malfunction (Bank #2)
P0331 Knock Sensor #2--Circuit Range/Performance (Bank #2)
P0332 Knock Sensor #2--Circuit Low Input (Bank #2)
P0333 Knock Sensor #2--Circuit High Input (Bank #2)
P0334 Knock Sensor #2--Circuit Input Intermittent (Bank #2)
P0335 Crankshaft Position Sensor "A" Circuit Malfunction
P0336 Crankshaft Position Sensor "A" Circuit Range/Performance
P0337 Crankshaft Position Sensor "A" Circuit Low Input
P0338 Crankshaft Position Sensor "A" Circuit High Input
P0339 Crankshaft Position Sensor "A" Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil "A" Primary/Secondary Circuit Malfunction
P0352 Ignition Coil "B" Primary/Secondary Circuit Malfunction
P0353 Ignition Coil "C" Primary/Secondary Circuit Malfunction
P0354 Ignition Coil "D" Primary/Secondary Circuit Malfunction
P0355 Ignition Coil "E" Primary/Secondary Circuit Malfunction
P0356 Ignition Coil "F" Primary/Secondary Circuit Malfunction
P0357 Ignition Coil "G" Primary/Secondary Circuit Malfunction
P0358 Ignition Coil "H" Primary/Secondary Circuit Malfunction
P0359 Ignition Coil "I" Primary/Secondary Circuit Malfunction
P0360 Ignition Coil "J" Primary/Secondary Circuit Malfunction
P0361 Ignition Coil "K" Primary/Secondary Circuit Malfunction
P0362 Ignition Coil "L" Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal "A" Malfunction
P0371 Timing Reference High Resolution Signal "A" Too Many Pulses
P0372 Timing Reference High Resolution Signal "A" Too Few Pulses
P0373 Timing Reference High Resolution Signal "A" Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal "A" No Pulses
P0375 Timing Reference High Resolution Signal "B" Malfunction
P0376 Timing Reference High Resolution Signal "B" Too Many Pulses
P0377 Timing Reference High Resolution Signal "B" Too Few Pulses
P0378 Timing Reference High Resolution Signal "B" Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal "B" No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Glow Plug/Heater Circuit "B" Malfunction
P0385 Crankshaft Position Sensor "B" Circuit Malfunction
P0386 Crankshaft Position Sensor "B" Circuit Range/Performance
P0387 Crankshaft Position Sensor "B" Circuit Low Input
P0388 Crankshaft Position Sensor "B" Circuit High Input
P0389 Crankshaft Position Sensor "B" Circuit Intermittent
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor "A" Circuit Low
P0406 Exhaust Gas Recirculation Sensor "A" Circuit High
P0407 Exhaust Gas Recirculation Sensor "B" Circuit Low
P0408 Exhaust Gas Recirculation Sensor "B" Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve "A" Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve "A" Circuit Open
P0414 Secondary Air Injection System Switching Valve "A" Circuit Shorted
P0415 Secondary Air Injection System Switching Valve "B" Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve "B" Circuit Open
P0417 Secondary Air Injection System Switching Valve "B" Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank #1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank #1)
P0422 Main Catalyst Efficiency Below Threshold (Bank #1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank #1)
P0424 Heated Catalyst Temperature Below Threshold (Bank #1)
P0430 Catalyst System Efficiency Below Threshold (Bank #2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank #2)
P0432 Main Catalyst Efficiency Below Threshold (Bank #2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank #2)
P0434 Heated Catalyst Temperature Below Threshold (Bank #2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (Small Leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (Gross Leak)
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan #1 Control Circuit Malfunction
P0481 Cooling Fan #2 Control Circuit Malfunction
P0482 Cooling Fan #3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Circuit Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Low Voltage
P0523 Engine Oil Pressure Sensor/Switch High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 A/C Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise Control On Signal Malfunction
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch "A" Circuit Malfunction
P0572 Cruise Control/Brake Switch "A" Circuit Low
P0573 Cruise Control/Brake Switch "A" Circuit High
P0574 Through P0580 Reserved for Cruise Codes
P0600 Serial Communication Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 PCM Processor Fault
P0608 Control Module VSS Output "A" Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfunction
P0656 Fuel Level Output Circuit Malfunction
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch "B" Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit Malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch "B" Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Circuit Range/Performance
P0722 Output Speed Sensor Circuit No Signal
P0723 Output Speed Sensor Circuit Intermittent
P0724 Torque Converter/Brake Switch "B" Circuit High
P0725 Engine Speed Input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear #1 Incorrect Ratio
P0732 Gear #2 Incorrect Ratio
P0733 Gear #3 Incorrect Ratio
P0734 Gear #4 Incorrect Ratio
P0735 Gear #5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0740 Torque Converter Clutch Circuit Malfunction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid "A" Malfunction
P0751 Shift Solenoid "A" Performance or Stuck Off
P0752 Shift Solenoid "A" Stuck On
P0753 Shift Solenoid "A" Electrical
P0754 Shift Solenoid "A" Intermittent
P0755 Shift Solenoid "B" Malfunction
P0756 Shift Solenoid "B" Performance or Stuck Off
P0757 Shift Solenoid "B" Stuck On
P0758 Shift Solenoid "B" Electrical
P0759 Shift Solenoid "B" Intermittent
P0760 Shift Solenoid "C" Malfunction
P0761 Shift Solenoid "C" Performance Or Stuck Off
P0762 Shift Solenoid "C" Stuck On
P0763 Shift Solenoid "C" Electrical
P0764 Shift Solenoid "C" Intermittent
P0765 Shift Solenoid "D" Malfunction
P0766 Shift Solenoid "D" Performance Or Stuck Off
P0767 Shift Solenoid "D" Stuck On
P0768 Shift Solenoid "D" Electrical
P0769 Shift Solenoid "D" Intermittent
P0770 Shift Solenoid "E" Malfunction
P0771 Shift Solenoid "E" Performance Or Stuck Off
P0772 Shift Solenoid "E" Stuck On
P0773 Shift Solenoid "E" Electrical
P0774 Shift Solenoid "E" Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P1000 OBD II Monitor Testing Not Complete More Driving Required
P1001 Key On Engine Running (KOER) Self-Test Not Able To Complete, KOER Aborted
P1100 Mass Air Flow (MAF) Sensor Intermittent
P1101 Mass Air Flow (MAF) Sensor Out Of Self-Test Range
P1111 System Pass 49 State Except Econoline
P1112 Intake Air Temperature (IAT) Sensor Intermittent
P1116 Engine Coolant Temperature (ECT) Sensor Out Of Self-Test Range
P1117 Engine Coolant Temperature (ECT) Sensor Intermittent
P1120 Throttle Position (TP) Sensor Out Of Range (Low)
P1121 Throttle Position (TP) Sensor Inconsistent With MAF Sensor
P1124 Throttle Position (TP) Sensor Out Of Self-Test Range
P1125 Throttle Position (TP) Sensor Circuit Intermittent
P1127 Exhaust Not Warm Enough, Downstream Heated Oxygen Sensors HO2S) Not Tested
P1128 Upstream Heated Oxygen Sensors (HO2S) Swapped From Bank To Bank
P1129 Downstream Heated Oxygen Sensors (HO2S) Swapped From Bank To Bank
P1130 Lack Of Upstream Heated Oxygen Sensor (HO2S 11) Switch, Adaptive Fuel At Limit (Bank #1)
P1131 Lack Of Upstream Heated Oxygen Sensor (HO2S 11) Switch, Sensor Indicates Lean (Bank #1)
P1132 Lack Of Upstream Heated Oxygen Sensor (HO2S 11) Switch, Sensor Indicates Rich (Bank #1)
P1137 Lack Of Downstream Heated Oxygen Sensor (HO2S 12) Switch, Sensor Indicates Lean (Bank #1)
P1138 Lack Of Downstream Heated Oxygen Sensor (HO2S 12) Switch, Sensor Indicates Rich (Bank #1)
P1150 Lack Of Upstream Heated Oxygen Sensor (HO2S 21) Switch, Adaptive Fuel At Limit (Bank #2)
P1151 Lack Of Upstream Heated Oxygen Sensor (HO2S 21) Switch, Sensor Indicates Lean (Bank #2)
P1152 Lack Of Upstream Heated Oxygen Sensor (HO2S 21) Switch, Sensor Indicates Rich (Bank #2)
P1157 Lack Of Downstream Heated Oxygen Sensor (HO2S 22) Switch, Sensor Indicates Lean (Bank #2)
P1158 Lack Of Downstream Heated Oxygen Sensor (HO2S 22) Switch, Sensor Indicates Rich (Bank #2)
P1169 (HO2S 12) Signal Remained Unchanged For More Than 20 Seconds After Closed Loop
P1170 (HO2S 11) Signal Remained Unchanged For More Than 20 Seconds After Closed Loop
P1173 Feedback A/F Mixture Control (HO2S 21) Signal Remained Unchanged For More Than 20 Seconds After Closed Loop
P1184 Engine Oil Temp Sensor Circuit Performance
P1195 Barometric (BARO) Pressure Sensor Circuit Malfunction (Signal Is From EGR Boost Sensor)
P1196 Starter Switch Circuit Malfunction
P1209 Injection Control Pressure (ICP) Peak Fault
P1210 Injection Control Pressure (ICP) Above Expected Level
P1211 Injection Control Pressure (ICP) Not Controllable--Pressure Above/Below Desired
P1212 Injection Control Pressure (ICP) Voltage Not At Expected Level
P1218 Cylinder Identification (CID) Stuck High
P1219 Cylinder Identification (CID) Stuck Low
P1220 Series Throttle Control Malfunction (Traction Control System)
P1224 Throttle Position Sensor "B" (TP-B) Out Of Self-Test Range (Traction Control System)
P1230 Fuel Pump Low Speed Malfunction
P1231 Fuel Pump Secondary Circuit Low With High Speed Pump On
P1232 Low Speed Fuel Pump Primary Circuit Malfunction
P1233 Fuel Pump Driver Module Off-line (MIL DTC)
P1234 Fuel Pump Driver Module Disabled Or Off-line (No MIL)
P1235 Fuel Pump Control Out Of Range (MIL DTC)
P1236 Fuel Pump Control Out Of Range (No MIL)
P1237 Fuel Pump Secondary Circuit Malfunction (MIL DTC)
P1238 Fuel Pump Secondary Circuit Malfunction (No DMIL)
P1250 Fuel Pressure Regulator Control (FPRC) Solenoid Malfunction
P1260 THEFT Detected--Engine Disabled
P1261 High To Low Side Short--Cylinder #1 (Indicates Low side Circuit Is Shorted To B+ Or To The High Side Between The IDM And The Injector)
P1262 High To Low Side Short--Cylinder #2 (Indicates Low side Circuit Is Shorted To B+ Or To The High Side Between The IDM And The Injector)
P1263 High To Low Side Short--Cylinder #3 (Indicates Low side Circuit Is Shorted To B+ Or To The High Side Between The IDM And The Injector)
P1264 High To Low Side Short--Cylinder #4 (Indicates Low side Circuit Is Shorted To B+ Or To The High Side Between The IDM And The Injector)
P1265 High To Low Side Short--Cylinder #5 (Indicates Low side Circuit Is Shorted To B+ Or To The High Side Between The IDM And The Injector)
P1266 High To Low Side Short--Cylinder #6 (Indicates Low side Circuit Is Shorted To B+ Or To The High Side Between The IDM And The Injector)
P1267 High To Low Side Short--Cylinder #7 (Indicates Low side Circuit Is Shorted To B+ Or To The High Side Between The IDM And The Injector)
P1268 High To Low Side Short--Cylinder #8 (Indicates Low side Circuit Is Shorted To B+ Or To The High Side Between The IDM And The Injector)
P1270 Engine RPM Or Vehicle Speed Limiter Reached
P1271 High To Low Side Open--Cylinder #1 (Indicates A High To Low Side Open Between The Injector And The IDM)
P1272 High To Low Side Open--Cylinder #2 (Indicates A High To Low Side Open Between The Injector And The IDM)
P1273 High To Low Side Open--Cylinder #3 (Indicates A High To Low Side Open Between The Injector And The IDM)
P1274 High To Low Side Open--Cylinder #4 (Indicates A High To Low Side Open Between The Injector And The IDM)
P1275 High To Low Side Open--Cylinder #5 (Indicates A High To Low Side Open Between The Injector And The IDM)
P1276 High To Low Side Open--Cylinder #6 (Indicates A High To Low Side Open Between The Injector And The IDM)
P1277 High To Low Side Open--Cylinder #7 (Indicates A High To Low Side Open Between The Injector And The IDM)
P1278 High To Low Side Open--Cylinder #8 (Indicates A High To Low Side Open Between The Injector And The IDM)
P1280 Injection Control Pressure (ICP) Circuit Out Of Range Low
P1281 Injection Control Pressure (ICP) Circuit Out Of Range High
P1282 Injection Control Pressure (ICP) Excessive
P1283 Injection Pressure Regulator (IPR) Circuit Failure
P1284 Injection Control Pressure (ICP) Failure--Aborts KOER Or CCT Test
P1285 Cylinder Head Temperature (CHT) Over Temperature Sensed
P1288 Cylinder Head Temperature (CHT) Sensor Out Of Self-Test Range
P1289 Cylinder Head Temperature (CHT) Sensor Circuit Low Input
P1290 Cylinder Head Temperature (CHT) Sensor Circuit High Input
P1291 IDM To Injector High Side Circuit #1 (Right Bank) Short To GND Or B+
P1292 IDM To Injector High Side Circuit #2 (Right Bank) Short To GND Or B+
P1293 IDM To Injector High Side Circuit Open Bank #1 (Right Bank)
P1294 IDM To Injector High Side Circuit Open Bank #2 (Left Bank)
P1295 Multiple IDM/Injector Circuit Faults On Bank #1 (Right)
P1296 Multiple IDM/Injector Circuit Faults On Bank #2 (Left)
P1297 High Sides Shorted Together
P1298 IDM Failure
P1299 Engine Over Temperature Condition
P1309 Misfire Detection Monitor Is Not Enabled
P1316 Injector Circuit/IDM Codes Detected
P1320 Distributor Signal Interrupt
P1336 Crankshaft Position Sensor (Gear)
P1345 No Camshaft Position Sensor Signal
P1351 Ignition Diagnostic Monitor (IDM) Circuit Input Malfunction
P1351 Indicates Ignition System Malfunction
P1352 Indicates Ignition System Malfunction
P1353 Indicates Ignition System Malfunction
P1354 Indicates Ignition System Malfunction
P1355 Indicates Ignition System Malfunction
P1356 PIPs Occurred While IDM Pulse width Indicates Engine Not Turning
P1357 Ignition Diagnostic Monitor (IDM) Pulse width Not Defined
P1358 Ignition Diagnostic Monitor (IDM) Signal Out Of Self-Test Range
P1359 Spark Output Circuit Malfunction
P1364 Spark Output Circuit Malfunction
P1390 Octane Adjust (OCT ADJ) Out Of Self-Test Range
P1391 Glow Plug Circuit Low Input Bank #1 (Right)
P1392 Glow Plug Circuit High Input Bank #1 (Right)
P1393 Glow Plug Circuit Low Input Bank #2 (Left)
P1394 Glow Plug Circuit High Input Bank #2 (Left)
P1395 Glow Plug Monitor Fault Bank #1
P1396 Glow Plug Monitor Fault Bank #2
P1397 System Voltage Out Of Self Test Range
P1400 Differential Pressure Feedback EGR (DPFE) Sensor Circuit Low Voltage Detected
P1401 Differential Pressure Feedback EGR (DPFE) Sensor Circuit High Voltage Detected/EGR Temperature Sensor
P1402 EGR Valve Position Sensor Open Or Short
P1403 Differential Pressure Feedback EGR (DPFE) Sensor Hoses Reversed
P1405 Differential Pressure Feedback EGR (DPFE) Sensor Upstream Hose Off Or Plugged
P1406 Differential Pressure Feedback EGR (DPFE) Sensor Downstream Hose Off Or Plugged
P1407 Exhaust Gas Recirculation (EGR) No Flow Detected (Valve Stuck Closed Or Inoperative)
P1408 Exhaust Gas Recirculation (EGR) Flow Out Of Self-Test Range
P1409 Electronic Vacuum Regulator (EVR) Control Circuit Malfunction
P1410 Check That Fuel Pressure Regulator Control Solenoid And The EGR Check Solenoid Connectors Are Not Swapped
P1411 Secondary Air Injection System Incorrect Downstream Flow Detected
P1413 Secondary Air Injection System Monitor Circuit Low Voltage
P1414 Secondary Air Injection System Monitor Circuit High Voltage
P1442 Evaporative Emission Control System Small Leak Detected
P1443 Evaporative Emission Control System--Vacuum System, Purge Control Solenoid Or Purge Control Valve Malfunction
P1444 Purge Flow Sensor (PFS) Circuit Low Input
P1445 Purge Flow Sensor (PFS) Circuit High Input
P1449 Evaporative Emission Control System Unable To Hold Vacuum
P1450 Unable To Bleed Up Fuel Tank Vacuum
P1455 Evaporative Emission Control System Control Leak Detected (Gross Leak)
P1460 Wide Open Throttle Air Conditioning Cut-Off Circuit Malfunction
P1461 Air Conditioning Pressure (ACP) Sensor Circuit Low Input
P1462 Air Conditioning Pressure (ACP) Sensor Circuit High Input
P1463 Air Conditioning Pressure (ACP) Sensor Insufficient Pressure Change
P1464 Air Conditioning (A/C) Demand Out Of Self-Test Range/A/C On During KOER Or CCT Test
P1469 Low Air Conditioning Cycling Period
P1473 Fan Secondary High, With Fan(s) Off
P1474 Low Fan Control Primary Circuit Malfunction
P1479 High Fan Control Primary Circuit Malfunction
P1480 Fan Secondary Low, With Low Fan On
P1481 Fan Secondary Low, With High Fan On
P1483 Power To Fan Circuit Over current
P1484 Open Power/Ground To Variable Load Control Module (VLCM)
P1485 EGR Control Solenoid Open Or Short
P1486 EGR Vent Solenoid Open Or Short
P1487 EGR Boost Check Solenoid Open Or Short
P1500 Vehicle Speed Sensor (VSS) Circuit Intermittent
P1501 Vehicle Speed Sensor (VSS) Out Of Self-Test Range/Vehicle Moved During Test
P1502 Invalid Self Test--Auxiliary Powertrain Control Module (APCM) Functioning
P1504 Idle Air Control (IAC) Circuit Malfunction
P1505 Idle Air Control (IAC) System At Adaptive Clip
P1506 Idle Air Control (IAC) Over-speed Error
P1507 Idle Air Control (IAC) Under-speed Error
P1512 Intake Manifold Runner Control (IMRC) Malfunction (Bank #1 Stuck Closed)
P1513 Intake Manifold Runner Control (IMRC) Malfunction (Bank #2 Stuck Closed)
P1516 Intake Manifold Runner Control (IMRC) Input Error (Bank #1)
P1517 Intake Manifold Runner Control (IMRC) Input Error (Bank #2)
P1518 Intake Manifold Runner Control (IMRC) Malfunction (Stuck Open)
P1519 Intake Manifold Runner Control (IMRC) Malfunction (Stuck Closed)
P1520 Intake Manifold Runner Control (IMRC) Circuit Malfunction
P1521 Variable Resonance Induction System (VRIS) Solenoid #1 Open Or Short
P1522 Variable Resonance Induction System (VRIS) Solenoid #2 Open Or Short
P1523 High Speed Inlet Air (HSIA) Solenoid Open Or Short
P1530 Air Condition (A/C) Clutch Circuit Malfunction
P1531 Invalid Test--Accelerator Pedal Movement
P1536 Parking Brake Applied Failure
P1537 Intake Manifold Runner Control (IMRC) Malfunction (Bank #1 Stuck Open)
P1538 Intake Manifold Runner Control (IMRC) Malfunction (Bank #2 Stuck Open)
P1539 Power To Air Condition (A/C) Clutch Circuit Over-current
P1549 Problem In Intake Manifold Tuning (IMT) Valve System
P1550 Power Steering Pressure (PSP) Sensor Out Of Self-Test Range
P1601 Serial Communication Error
P1605 Powertrain Control Module (PCM)--Keep Alive Memory (KAM) Test Error
P1608 PCM Internal Circuit Malfunction
P1609 PCM Internal Circuit Malfunction (2.5L Only)
P1625 B+ Supply To Variable Load Control Module (VLCM) Fan Circuit Malfunction
P1626 B+ Supply To Variable Load Control Module (VLCM) Air Conditioning (A/C) Circuit
P1650 Power Steering Pressure (PSP) Switch Out Of Self-Test Range
P1651 Power Steering Pressure (PSP) Switch Input Malfunction
P1660 Output Circuit Check Signal High
P1661 Output Circuit Check Signal Low
P1662 Injection Driver Module Enable (IDM EN) Circuit Failure
P1663 Fuel Delivery Command Signal (FDCS) Circuit Failure
P1667 Cylinder Identification (CID) Circuit Failure
P1668 PCM--IDM Diagnostic Communication Error
P1670 EF Feedback Signal Not Detected
P1701 Reverse Engagement Error
P1701 Fuel Trim Malfunction (Villager)
P1703 Brake On/Off (BOO) Switch Out Of Self-Test Range
P1704 Digital Transmission Range (TR) Sensor Failed To Transition State
P1705 Transmission Range (TR) Sensor Out Of Self-Test Range
P1705 TP Sensor (AT) Villager
P1705 Clutch Pedal Position (CPP) Or Park Neutral Position (PNP) Problem
P1706 High Vehicle Speed In Park
P1709 Park Or Neutral Position (PNP) Or Clutch Pedal Position (CPP) Switch Out Of Self-Test Range
P1709 Throttle Position (TP) Sensor Malfunction (Aspire 1.3L and Probe 2.5L)
P1711 Transmission Fluid Temperature (TFT) Sensor Out Of Self-Test Range
P1714 Shift Solenoid "A" Inductive Signature Malfunction
P1715 Shift Solenoid "B" Inductive Signature Malfunction
P1716 Transmission Malfunction
P1717 Transmission Malfunction
P1719 Transmission Malfunction
P1720 Vehicle Speed Sensor (VSS) Circuit Malfunction
P1727 Coast Clutch Solenoid Inductive Signature Malfunction
P1728 Transmission Slip Error--Converter Clutch Failed
P1729 4x4 Low Switch Error
P1731 Improper 1-2 Shift
P1732 Improper 2-3 Shift
P1733 Improper 3-4 Shift
P1734 Improper 4-5 Shift
P1740 Torque Converter Clutch (TCC) Inductive Signature Malfunction
P1741 Torque Converter Clutch (TCC) Control Error
P1742 Torque Converter Clutch (TCC) Solenoid Failed On (Turns On MIL)
P1743 Torque Converter Clutch (TCC) Solenoid Failed On (Turns On TCIL)
P1744 Torque Converter Clutch (TCC) System Mechanically Stuck In Off Position
P1744 Torque Converter Clutch (TCC) Solenoid Malfunction (2.5L Only)
P1746 Electronic Pressure Control (EPC) Solenoid Open Circuit (Low Input)
P1747 Electronic Pressure Control (EPC) Solenoid Short Circuit (High Input)
P1748 Electronic Pressure Control (EPC) Malfunction
P1749 Electronic Pressure Control (EPC) Solenoid Failed Low
P1751 Shift Solenoid #1 (SS1) Performance
P1754 Coast Clutch Solenoid (CCS) Circuit Malfunction
P1756 Shift Solenoid #2 (SS2) Performance
P1760 Overrun Clutch SN
P1761 Shift Solenoid #3 (SS3) Performance
P1762 Transmission Malfunction
P1765 3-2 Timing Solenoid Malfunction (2.5L Only)
P1779 TCIL Circuit Malfunction
P1780 Transmission Control Switch (TCS) Circuit Out Of Self-Test Range
P1781 4x4 Low Switch, Out Of Self-Test Range
P1783 Transmission Over Temperature Condition
P1784 Transmission Malfunction
P1785 Transmission Malfunction
P1786 Transmission Malfunction
P1787 Transmission Malfunction
P1788 3-2 Timing/Coast Clutch Solenoid (3-2/CCS) Circuit Open
P1789 3-2 Timing/Coast Clutch Solenoid (3-2/CCS) Circuit Shorted
P1792 Idle (IDL) Switch (Closed Throttle Position Switch) Malfunction
P1794 Loss Of Battery Voltage Input
P1795 EGR Boost Sensor Malfunction
P1797 Clutch Pedal Position (CPP) Switch Or Neutral Switch Circuit Malfunction
P1900 Cooling Fan
U1021 SCP Indicating The Lack Of Air Conditioning (A/C) Clutch Status Response
U1039 Vehicle Speed Signal (VSS) Missing Or Incorrect
U1051 Brake Switch Signal Missing Or Incorrect
U1073 SCP Indicating The Lack Of Engine Coolant Fan Status Response
U1131 SCP Indicating The Lack Of Fuel Pump Status Response
U1135 SCP Indicating The Ignition Switch Signal Missing Or Incorrect
U1256 SCP Indicating A Communications Error
U1451 Lack Of Response From Passive Anti-Theft System (PATS) Module--Engine Disabled
