Kłopoty z EGR -> czyżby słaba strona jedynek?
: 2005-06-03 11:21
hehe..
kopię sobie w necie i znalazłem info, że nie tylko my tutaj mamy kłopot z check engine i kodem EGR valve...
poniżej korespondencja po zgłoszeniu autka do serwisu w usa na tę samą dolegliwość:
J.P. King
Manager
Parts and Service Engineering
Ford Parts and Service Division
......................................................Ford Motor Company
.....................................................3000 Schaefer Road
......................................................P.O. Box 1902
......................................................Dearborn, Michigan 48121
February, 1993
Mr. John Sample
123 Main Street
California, USA 12345
Ford Motor Company is voluntarily recalling (Emissions Recall 92E34) certain 1990, 1991 and 1992-Model California Probe GT cars equipped with 2.2L (Turbo) engines. Your Probe's "check engine" warning light may come on when there is no engine problem.
What The Dealer Will Do
At no cost to you, your dealer will replace the exhaust gas recirculation valve and sensor on your Probe according to the instructions provided by Ford.
This service should have little or no effect on your Probe except to improve the operation of the "check engine" warning light system.
If you do not have this service done,
* Your emissions warranty may be reduced,
* Your Probe may not pass emissions inspections or smog tests that may be required in your area,
* The California Department of Motor Vehicles (DMV) may not renew your vehicle registration.
How Long Will It Take?
The time needed to repair your Probe is about one hour. However, due to service scheduling times, your dealer may need your car one full working day.
Call Your Dealer
Call your dealer without delay. Ask for a service date and if parts are in stock.
If your dealer does not have the parts in stock, they can be ordered before scheduling your service date. Parts would be expected to arrive within a week.
When you bring your Probe in, present this letter to the dealer.
If you misplace this letter, your dealer will still do the work, free of charge.
Changed Address Or Sold The Car?
If you have, please fill out the enclosed prepaid postcard and mail it to us.
If the dealer doesn't make the repair promptly and without charge, you may contact the Ford Customer Assistance Center by calling toll-free 1-800-392-3673, (1-800-392-FORD).
The State of California requires the completion of emissions repairs prior to vehicle registration renewal. Your Probe is subject to these requirements. When this recall repair is completed by your dealer, you will receive a Vehicle Emission Recall - Proof of Completion certificate. This certificate says that this emissions recall has been performed on your car.
Please make sure that you get a certificate from the dealer and that you have it when you renew your car's registration.
It is also important for you to know that the certificate should be returned to the department of Motor Vehicles (DMV) only if it is requested. Otherwise, the certificate is to be held by you for your records.
We regret any problem this recall may cause you. We are doing this so you will be satisfied with your Probe. In order to ensure your full protection under the emission warranty provisions and to avoid any inconvenience when renewing your registration, it is recommended that you have your car serviced as soon as possible. Failure to do so could be determined as lack of proper maintenance of your car.
Sincerely,
J.P. King
więc jak widać...
:D:D
może jakies pomysły?
J.P. King
Manager
February, 1993
Mr. John Sample
123 Main Street
Call Your Dealer
Sincerely,
J.P. King
więc jak widać...
