Dzis sie zabieram za wyciagniecie wkładki do zamka bagaznika juz szczesliwy zaczynam rozkrecac a tu..... dupa niewiem jak sie tam dostac :/
Moze ktos z Was wie i moglby mnie osiwiecic bo ja niemam pojecia :/
Liftgate Lock Cylinder RemovalNOTE:
- Remove the interior end trim panel.
- Open liftgate to allow for the trunk end trim to be removed.
- Remove twelve plastic clips from the trunk end trim.
- Remove trunk end trim.
- Remove both tail lamp assemblies.
- Remove the center lens assembly.
- Remove two screws, lock cylinder and gasket.
Inspect the retaining screws for looseness. If the original screws do not fully secure the lock cylinder, replace the screws with ones that have a larger diameter, such as license plate screws.
